I have a Cv value for an OEM part. I model a disk with certain diameter "d". I use Cv relation: Q=Cv*sqrt(dp/SG).
Then using relation ,and using diameter of disk "d", i calculate the value of "thru flow k factor" and use in my model. But the model and Cv equation give different results with an error of about 33% for water.
