CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Residualier data
7 REPLIES 7
Message 1 of 8
568 Views, 7 Replies
Residualier data
How to get Residual data from simulation resultat?
Tags (1)
7 REPLIES 7
Message 2 of 8
OmkarJ
These are available under "Resid In" and "Resid out" parameters.
OJ
Message 3 of 8
in reply to: OmkarJ
In witch document?
Message 4 of 8
OmkarJ
When you look at the convergence plots, at the right hand side you have tabs labeled Global, All, Avg etc. Click on Avg, you will have then the option to view "Resid In" and "Resid Out".
OJ
Message 5 of 8
in reply to: OmkarJ
Thanks 🙂
Message 6 of 8
in reply to: OmkarJ
Hi OJ
Can see this plot and when I save it is not any value of "Resid Out" ?
Can you explain me more precise how to catch "Resid Out " value ?
Regards
Sveinn
Message 7 of 8
Royce_adsk
Just wanted to make you aware there is a fairly detailed discussion about these quantities in the help:
http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0030-User_Int30/0066-Output_B66/0067-Conve...
If you want to see the actual values instead of the trend look at the table tab instead of plot.
Royce.Abel
Technical Support Manager
Message 8 of 8
OmkarJ
in reply to: Royce_adsk
The resid out value per se may not be too useful since it is not normalised one (like other CFD codes, eg FLUENT, CFX etc). Rather, the ratio of resid in and resid out provides more insight into convergence.
Have a look at following thread where it is discussed.
http://forums.autodesk.com/t5/Autodesk-Simulation-CFD/CONVERGENCE-CRITERIA/m-p/3721810#M1129
OJ
