CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Required velocity as simulation result
1 REPLY 1
316 Views, 1 Reply
I am looking what simulatin CFD is capable of, and i have a question:
Say we use Faucet example model we get with instalation. I know I what to get 30C water running from the tap outlet. I know I have 50C hot inlet, and 7C cold inlet. Is there a way to find out what velocity I need for input to get desired temperature in the outlet?
This question should sound like: Can I find out what Boundary conditions should be to get desired result, insted of adding  boundary conditions and simulate to see what happens?
I see there is Boundary conditions "unknown", maybe it could help?
1 REPLY 1
Jon.Wilde
Hi Valdas,
Not at present no.
What you could do is run a batch of simulations using the clone feature, all with differing flow rates and then run a comparison to find a trend, fit a graph and extrapolate to the desired figure.
