CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Recover mesh cycles
5 REPLIES 5
519 Views, 5 Replies
Recover mesh cycles
I have run several adaptive mesh cycles with my model when the simulation crashed. Now, if I try to open again the file none of the meshing cycles appear, and all results are lost.
Nevertheless, if I open the "Design1" folder where I saved my simulation, I can see all the subfolder with the cycles I run, that is, "Scenario 1", "Scenario 1 - Mesh 1", etc...
Is there any way to recover and open this data?
5 REPLIES 5
you can try to open the cfz support file and replace the support folder with original folder.
I tried but it doesn't work
Thanks anyway.
Jon.Wilde
If you have any .res files in the scenario folder you can try a similar approach:
  1. Open the support file
  2. Close and save the support file
  3. Copy over a .res file from the old analysis to the new analysis
  4. Open new project again
  5. Run for 0 iterations and see if the results appear
There is no surefire way to guarantee this but we find that this technique often works well.
It worked 🙂
terihall
in reply to: Jon.Wilde
Hi Jon,
I am running into a similar issue.
Could you be a little bit more specific about which .res files you moved and where you moved them to?
I have tried moving just the .res file from the final mesh, e.g.:
file\Design 1\Scenario 1\solver\Scenario 1.res.s713
to
file_support\Design 1\Scenario 1\solver\Scenario 1.res.s713
When this didn't work, I also tried recreating the file structure in the new design folder and have moved the .res files from each mesh adaptation as well, e.g.:
file\Design 1\Scenario 1 - Mesh 1\solver\Scenario 1 - Mesh 1.res.s902
to
file_support\Design 1\Scenario 1 - Mesh 1\solver\Scenario 1 - Mesh 1.res.s902
Each of these results in the following output upon running for 0 iterations:
*********** ANALYSIS STARTED ***********
Turbulent Incompressible Flow is ON
Turbulence model: SST_k-omega
Intelligent Wall Formulation: ON
Begin Post-Processing Calculations ...
Post-Processing Calculations Done
Begin Post-Processing File Output ...
Post-Processing File Output Done
Analysis completed successfully
Adaptive meshing process started...
Loading model...
Loading mesh sizes and constraints...
Computing adaptive mesh sizes...
Mesh adaptation has failed.
I'd really appreciate any insight. This has happened to about 10 similar jobs of a set of about 100 similar jobs so I don't think that it is a mesh issue.
Let me know if you need any additional information or if I am being unclear about anything. Thanks!
Tags (1)
