My simulation always crashes when I try to invoke Mesh Size -> Rebuild mesh generation. I believe that will re-run the Mesh Macro. Are other experiencing this issue. Is there a workaround I could use?
One typical workaround I spotted is to delete any uniform mesh setting on surfaces, rebuild the mesh and apply uniform settign again. It generally works. Or a bit lengthy workaround is to take a snapshot of meshing tree and then redo the mesh. Takes few minutes but works generally.
