Just got this software about a month and a half ago, and just started using it heavily on my projects. I did a few tutorials that seemed relevant. What I am not finding are any good instructions on what results visualizations options are available, or it may be simply that they're not.
Can we alter the range on the results display? If so, how?
Is there a dynamic probe available, where we can pick on the screen to view a result for that area/node? If not, how can we query specific points on the model?
Seems like there's a means of viewing some dynamic illustration of the steps/analysis. Haven't figured out how, and the tutorials I reviewed didn't do much more than repeatedly show me how to create a cutting plane. Can I create dynamic results? Or, again, any good links to instructions on using that functionality?
Or, better yet, is there a comprehensive instruction on all results options that I can go through and answer my own questions?
Solved by Royce_adsk. Go to Solution.
Hi John,
A lot of the basic clicks and picks and working with the results is covered in our essential skills videos series.
http://help.autodesk.com/view/SCDSE/2014/ENU/?guid=GUID-460A1E3E-D4ED-48C3-B9F1-FC8925B22CFA
To be more specific:
Legend Manipulation in this video: http://help.autodesk.com/view/SCDSE/2014/ENU/?guid=GUID-54831A4D-85C5-4D7C-8AEE-06E1EE32DEF3
Results Probing (ie Dynamic Probe): http://help.autodesk.com/view/SCDSE/2014/ENU/?guid=GUID-FD7323DF-92E0-46DB-BE97-04DB72282FAB
Point Results to precise point results: http://help.autodesk.com/view/SCDSE/2014/ENU/?guid=GUID-1C156F2F-4401-4636-AC32-9C8F7888BB76
Results Animation: http://help.autodesk.com/view/SCDSE/2014/ENU/?guid=GUID-A815C3A3-375F-43EC-95FE-E2669A17DC93 <-- Remember you need to have more than 1 saved results which is controled by results intervals.
I think that is a great place to start as you start digging into the documentation. If you really want to dig into the help read through the 'Process' section of the help.
