CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Question about Symmetry
2 REPLIES 2
brandonnoska
693 Views, 2 Replies
I have a model with several solid and fluid objects and when divided along a symmetry line it creates several solid and fluid surfaces including the heat source surface; i.e. the heat source is also divided along the symmetry line.  When I use the symmetry boundary condition, do I need to apply the boundary condition to all surfaces or only the fluid surfaces?  I think the answer is only the fluid surfaces based on my understanding of the symmetry boundary condition, but I need some clarificaiton to be sure.
Also, can symmetry be used to divide a compact thermal model object; i.e. my heat source is a CTM rather than just a a solid obejct, so do I need to apply symmetry to the compact thermal model surfaces as well?
BN
2 REPLIES 2
you'll only need the fluid faces. Also the thermal resistances of the CTM's have to be doubled (if they are cut in 2 halfs) to get the same results as for the full model.
Dipl.-Ing. (FH) Marco Müller
Application Engineer Digital Simulation
Mensch und Maschine Deutschland GmbH
www.mum.de/cfd
Thanks.  I did not realize that I needed to cut the Rjc in half.  I did know that you have to cut the power by 1/2, but not the Rjc.
