CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Python and Mesh Enhancement
4 REPLIES 4
497 Views, 4 Replies
I am trying to do a case study to see how mech enhancement can modify the results. I am writing a python script to generate designs and scenarios, but I have trouble in finding which is the property of the Scenario for layer gradation when it is not automatic.
I have found the Number of layers, layer factor, and also automaticLayerAdaptation which is a string On Off but if I have a layer gradatio of 1.2 what is the property which should I set?
Thanks for help
4 REPLIES 4
Royce_adsk
I don't believe that settings was available yet in the API.
You could use this flag: mesh_enhance_gradation
To set flags with the API refer to the code below:
def SetFlags(flagsList = None):
	# flagsList = {flagName:Value,flagName2:Value}
	if flagsList == None:
		CFD.DSE.UI.ShowMessage("Error: Needs Flags when using SetFlags")
	else:
		tempDir = tempfile.gettempdir()
		fileName = tempDir +"\\qtScript.script"
		try:
			f = open(fileName, "w")
			try:
				f.write("study = new DesignStudy;\n")
				f.write("scenario = study.activeScenario();\n")
				for flag in flagsList:
					f.write("scenario.addFlag(\"" + flag + "\"," + str(flagsList[flag]) + ", 0);\n")
			except:
				CFD.DSE.UI.ShowMessage("Error: Writing to: " + fileName)
			finally:
				f.close()
		except IOError:
			CFD.DSE.UI.ShowMessage("Error: Creating file: " + fileName)
			pass
		DSE.UI.ExecuteQtScript(fileName)
Royce.Abel
Technical Support Manager
in reply to: Royce_adsk
But I have observed that the flag mesh_enhance_gradation has the same value as enhancementStretching property of Scenario could be the same?
Some quick questions about the mesh_enhance falgs:
mesh_enhance_thick  I think it should be Layer Factor from Enhancement but the flag has values of 100 and in the layer factor I have values of 0.45 till 1.2
When these flags are applyed on the study, because I have manually modified the mesh_enhance_gradation and if I open the Boundary Mesh Engancement dialog box nothing is changed.
I presume that a value of 1 in mesh_enhance_gradation should account for the Auto value of Layer Gradation in the dialog box.
Thanks for help.
Royce_adsk
That flag doesn't change the UI, it just overrides the setting in the UI at the mesher executable level.
Royce.Abel
