Hi everyone,
I tried multiple settings and read almost all the tutorials, but I'm still not sure how accurate my simulation is. It's a fan to which a long motor is attached.
I made big Inlet and Outlet models and set the boundary conditions: pressure = 0 Pa.
RPM is 10000, but I'm not sure if the rotational speed table is correct I made. Could anyone check and give any advice?
I solved 100 steps, should it be more? I measured the velocity in z-axis, which is approx. -1.8 m/s, this seems to me to be little?
I attached the cfz file. Thanks everyone for any help and advice!
Best regards
Andyn
Solved by Jon.Wilde. Go to Solution.
Some thoughts:
I am in the middle of preparing a hangout session on just this subject for the 16th of July, keep an eye out on the forum for the invite.
Jon
Hi Jon,
First at all, thank you a lot for the fast answer!
To your 1. point:
I chose a bigger inlet and outlet because it was described in the following article:
http://help.autodesk.com/view/SCDSE/2015/ENU/?guid=GUID-D4AC8C6F-4806-4E02-8947-911F363EFAAF
"Extend the suction (inlet) and discharge (outlet) at least 3-4 hydraulic diameters from the impeller. This is necessary to prevent the boundary conditions from directly influencing the results."
But I changed the geometry as you said.
To your 2. point:
Thank you very much for the speed table. As you maybe noticed I used (or at least tried) the 3 phase strategy, also explained in the link above. But there are still many incomprehensibilities in their explanation. Could you please explain in your hangout session how such a table is designed. For example why are 50 steps needed for the ramp-up? Is it program specific? Also would be nice if you could explain the relation between time-steps and number of iterations.
To your 3. point:
Did it exactly as you said. Thanks! But a tutorial about how to apply a good mesh would be nice (for different geometries and scenarios). I hope I did it as you have been meaning it.
To your 4. point:
I did as you said, but after reading in the model with the T-shape RR, CFD divided the impeller and the motor in two parts, also the RR "Impeller-part" and the RR "Motor-part". So i just applied to both RR the same RR specifications, but then the solver exited unexepectedly. So I just deleted the Motor part. Now it's working fine.
To your 5. point:
In the attached file I iterated 100 times, just as a first try. Will let compute it now longer.
Thanks againg, I'm looking forward to seeing your hangout session.
Sincerley, Andyn
Hi Andyn,
No problem at all, when I can I like to help as much as possible. I think sometimes coffee helps me work a little faster 🙂
My responses:
1) I understand what you mean about the inlet and outlet now - it actually means extend the length along the axis and not the radius. So the outlet here needs to be much longer, 10x it's diameter in length 🙂
2) 50 steps are just what we use from experience, I am sure that other values would work but it is good to have just one message.
There is not such a great relationship between timesteps and number of iterations. Only really that with a transient simulation, you would typically need more iterations the smaller the timestep to reach the same 'real-time' value.
The actual number of timesteps we run for is not important, what is, is that we run enough to achive a stable solution.
The torque output and also monitor points help to quantify this.
3) The issue here is that your blades are a single surface. Ideally the leading and trailing edges are separate so you can give them an extra refined uniform mesh, much like this from a different model:
It is hard to know when we have an optimum mesh without a mesh sensitivity study. Really you need to clone the scenario, refine the mesh futher (say to 0.7) and compare the results. If they are different (by more than 5%), then the change in mesh had a significant impact, so refine and try again.
4) Really the RR should split the gap between the turbine and the wall, not be the wall. I would reduce it's diameter so that it sits halfway between impeller and wall of the tube. This should help, although I would also ask - is there really a wall in existence? Maybe there is for testing?
5) Great, it will surely need to run a long while.
Jon
