Discussion Groups
Simulation CFD
Active Member
adesk360
Program crashing
324 Views, 3 Replies
11-28-2012 11:59 AM
I run multiple simulations off the Autodesk cloud environment. Recently most of the simulation files crash when I open them (at the time simulation is running or after it is finished). It only opens maybe 2 simulations out of 10 correctly and the rest crash. First I thought the reason is running too many simulations at a time that is causing problems in downloading the files (I was running over 15 elements (scenarios or design studies) at the same time) so I reduced that to under 7 or 8 hoping it will solve the problem. Unfortunately it is getting worse now. Now, every now and then an error pops up from the simulation job manager saying: "Delta file is missing or corrupt". I have 16 GB of RAM on my machin and I don't think the problem is associated with this.
Any help is extremely appreciated.
Please use plain text.
Active Member
adesk360
Re: Program crashing
11-28-2012 12:39 PM in reply to: adesk360
I attached a snapshot of the simulation job manager showing that it is unable to download the files.
New Member
studio.btg
11-29-2012 12:46 PM in reply to: adesk360
I have exactly the same issue as mentioned above.
Can autodesk tell what is the reason of that and how to overcome this problem?
New Member
adole
02-21-2013 10:20 AM in reply to: studio.btg
Was a solution ever found for this problem.  I am also getting the "Delta file is missing or corrupt" error.
