Discussion Groups
Simulation CFD
Active Contributor
6 Kudos
Problems with geometry
182 Views, 2 Replies
01-26-2013 08:55 PM
I have been trying to run an airfoil. The runtimes were high so I have tried to run 2D CFD's. I cannot get any Inventor sketch accepted by Simulation 360 CFD Trial. Even a simple rectangle produces the screenshot I have attached. I am assuming you make a sketch in Inventor and then launch the CFD program to start a 2D CFD analysis. Am I wrong in that assumption?
I haven't found much in the help files for 2D anything. That is frustrating.
Is there a rule of thumb figure on how much faster a 2D analysis is versus a 3D analysis?
Distinguished Contributor
34 Kudos
Re: Problems with geometry
01-28-2013 08:24 PM in reply to: L103i050S
I am guessing that you drew the sketch and then launched Sim CFD from the Inventor plug-in without generating the 2D surface itself. If that's the case, you will need to generate the 2D surface in inventor using 3D Model>Surface>Patch tool, only then should you launch Sim CFD.
Active Contributor
6 Kudos
01-28-2013 10:07 PM in reply to: ilyas
Many thanks buddy. You spotted the mistake I was making.
