Discussion Groups
Simulation CFD
Active Member
0 Kudos
Problems with extracting aerodynamic data for a flight simulator
253 Views, 15 Replies
07-22-2014 04:10 AM
So I am trying to extract aerodynamic data (Cm,Cn,Cl,CL,CN,CD) out of a CAD-model in both different aerodynamic angles and in different Mach's. Is there any tutorial or something out there that I have missed? I've been through the official ones (drag coefficient for the car and supersonic simulation for the bullet) but doing these generates data that doesnt match the data I already have from real wind-tunnel tests. Sometimes it matches somewhat but not always. I am currently wondering about the Torque-axis in the wall-calculator, is this to be set to 0 or use the suggested values to have it measure in the middle of the model? Whats odd is that changing the velocity gives different standardized coefficient. The formula I use is: Coefficient=Total Moment/(Dynamic Pressure * Real aircraft area * Total area as shown in Wall Calculator)
Any suggestions?
Valued Contributor
6 Kudos
Re: Problems with extracting aerodynamic data for a flight simulator
07-25-2014 12:45 AM in reply to: RagnarDa
Hi RagnarDa !
I faced the same problem as Autodesk Simulation CFD doesn't provide direct aerodynamics data like Cd or Cl like ANSYS Fluent. You have to calculate those from Drag force and Lift Force using wall calculator of Simulation CFD.
I found this pdf that i attached helpful.
Hope it would help. Thanks!
Simanto
Active Member
0 Kudos
07-25-2014 05:26 AM in reply to: RagnarDa
Thanks but I already did that tutorial. Where did they get the front area number from?
Employee
16 Kudos
07-25-2014 06:41 AM in reply to: RagnarDa
The front area number is usually the chord length (in the flow direction) of the body or air-foil.
Hope this helps.
Valued Contributor
6 Kudos
07-25-2014 09:23 AM in reply to: RagnarDa
Hi!
Area should be like this picture.
Hope this helps.
Thank you!
Simanto
107 Kudos
07-31-2014 12:55 AM in reply to: hs.simanto
Simanto,
Fancy sketch btw :smileyhappy:
Valued Contributor
6 Kudos
07-31-2014 03:58 AM in reply to: OmkarJ
Hi OmkarJ!
thanks! :smileyhappy: actually this sketch is not mine,took it from a video used in sustainabilityworkshop by autodesk!
Simanto
Active Member
0 Kudos
08-19-2014 01:07 AM in reply to: RagnarDa
Thanks for all the replys! The replies didn't help me though. When using the solutions that is suggested I get completely erronious results. An example:
If I test my model at 30 alpha 0 beta ~around Mach 0.5 (171.605 m/s) at sea level conditions i get the following results in the wall calculator (I removed the six walls of the bounding box from the calculations):
Summary       -------------------
Total area 224.348 m^2
TOTAL FX -101726 Newton
TOTAL FY 2769050 Newton
TOTAL FZ -9520.9 Newton
Center of Force about X-Axis (Y-Z) 5.52947 6.87737 m
Center of Force about Y-Axis (X-Z) 1.19719 6.8917 m
Center of Force about Z-Axis (X-Y) 0.121217 5.70515 m
TOTAL MX -19096400 N-m
TOTAL MY -689668 N-m
TOTAL MZ 916020 N-m
Torque 916020 N-m
I am unsure which one of the moments is the pitch but if I calculate using MX (???) which is largest I get:
q = 0.5 * 1.2041 * (171.605 * 171.605) = 17729.3345808512
Cm = -19096400 / (q * 43 * 7.4) = -3.3850017048
which is far from my reference which is a wind tunnel testing data and is around -0.075. The 43 is the wing area and 7.4 is the chord length.
What is also odd is that if I change the velocity I get yet other values.
Any help?
Valued Contributor
51 Kudos
08-19-2014 06:02 AM in reply to: RagnarDa
Note that you must be using the same moment reference axis to match published data. Most airoil data where a pitching moment is given has the reference at quarter chord; some use the leading edge (see notes here, for example: http://www.dept.aoe.vt.edu/~lutze/AOE3104/airfoilwings.pdf).
In SimCFD you do this in the wall calculator by selecting "Torque" and assigning a point on the centerline at the quarter chord location, and assign the axis to point in the direction of the pitch axis.
Valued Contributor
51 Kudos
08-19-2014 06:03 AM in reply to: nhahn
Also, try at a much lower angle of attack, say 2 to 5 degrees -- most airfoils will stall above 12-15 degrees pitch so the data will be poor.
