Dear all,
I have a problem with the simulation of the compressor-box (picture below) ventilation. I have tried to simulate 12 fans (1 fan under each of the crankcases) and 2 fans on the top of the box, as a constant value, the simulation had not any problem, but when I have simulated them with defined the fan curves, the simulation diverged (The analysis has stopped because the Solver has exited unexpectedly). I have to stabilize the Solver, but I do not know how. Can anyone help me?
I have set them as a Centrifugal pump (2 fans on the top suck from the box and blow on the side (radial fan), the other works like basic axial fan)
Thank You very much for answer.
Solved by Jon.Wilde. Go to Solution.
I can make a few basic points to check initially
