Discussion Groups
Simulation CFD
0 Kudos
problem in launching cfd simulation from solid works
229 Views, 3 Replies
07-03-2012 01:04 PM
i couldnt launch autodesk cfd simulation from solidworks.
i tried to open it in active mode in solidworks its not even responding.
please somebody help me because i need to work on simulation immediately
Product Support
149 Kudos
Re: problem in launching cfd simulation from solid works
09-03-2012 03:04 AM in reply to: hareesh.kalyan
Hi, it looks as though this post was missed, are you still having problems?
Jon Wilde
New Member
0 Kudos
10-02-2012 01:39 PM in reply to: wildej
I am having trouble trying to launch SIMCFD from Solidworks using the Active Model button. It will look like it's trying to start up then the home screen of SIMCFD will flash for a second and then nothing comes up.
Product Support
149 Kudos
10-08-2012 03:08 AM in reply to: hareesh.kalyan
Are you able to run CFD normally?
It might be that you do not have the file saved locally, or maybe the security settings of the folders you are working within.
Jon Wilde
