I've just discovered a bug. It can be re-created by doing these steps:
- Run model, get results.
- Adapt mesh once, solve again
- Part way through solving, stop the solution
- Attempt to re-start the simulation using the adapted mesh
When I try to re-start the simulation, it will only re-start using the un-adapted mesh.
Is this a known bug? Have other people had it?
Hi Rob,
What do you mean by re-start the simulation? When continuing from the part way solved sequence, the adaption is visible. If I re-start from 0 iterations, the expectation is to start over. You might find this link of interest:
http://help.autodesk.com/view/SCDSE/2015/ENU/?guid=GUID-CB2F0968-7149-4679-AC93-DD2D4070BD13
Peggy☻
Hi Peggy,
When I say re-start, I mean pressing solve and selecting to re-start from the numbered last result on the adapted mesh.
RobT
Hi Rob,
There must be more to your steps. I believe I repeated everything you wrote but cannot see the issue you are reporting. I used a tutorial model and repeated your steps line by line. If you still see the issue, you may want to contact support team for more detailed troubleshooting.
Peggy
