Discussion Groups
Simulation CFD
Active Member
picirrottola
plugin "SimCFD to Simulation Mechanical"
117 Views, 1 Replies
01-31-2014 08:14 AM
Hi to everybody.
I'm trying to install the app plugin in subject, but w/o fortune.
Applications seems to be installed correctly, but I don't  see its icon in Plugin Toolbar of CFD 360 2014.
I installed a new app (SimCFD Pump Automation) and this new works fine.
So, I tried to execute SimCFDConfig.exe, but the only result is that using the tool AppManager.exe NO APP IS LISTED, but they works (except SimCFD to Simulation Mechanical, of course).
Can someone help me?
Thanks a lot
             Piero
Workstation: 4core AMD Opteron, WindowsXP-64bit
SW: Autodesk 360 Professional 2014
Piero Cirrottola
Please use plain text.
Active Member
picirrottola
Re: plugin "SimCFD to Simulation Mechanical"
01-31-2014 09:01 AM in reply to: picirrottola
some other info.
If I run AppManager.exe w/o any argument (only double-clicking on it in directory list) I see any plugin installed (look at image -OK).
But, if I launch it using the default installed icon (using full command:
"C:\Program Files\Autodesk\Simulation 360 2014\Simulation CFD 360 2014\AppManager.exe" SimCFD /U http://apps.exchange.autodesk.com/apps/v1/homepage?productline=SCFD&release=2013&language=en&utm_sou...
I don't se anything (look at image -NO).
Many thanks
             Piero
Piero Cirrottola
