Dear Simulation CFD experts,
I did a transient conjugate heat transfer case. Is there a way to plot (or store) the temperature as a function of time on a set of locations (say given a set of x,y,z)? The locations might be in air domain or solid.
Thanks!
Pei-Ying
Solved by Royce_adsk. Go to Solution.
Hi Pei-Ying,
You are going to want to look into reading about monitor points:
Hi, Royce,
The monitoring point can be used prior to start running the case. How about the calculations have been completed. Say, I save results every 10 min and the case is a 2-hour case. How to plot (or save) the temperature at a specific location as a function of time?
Pei-Ying
