Great to see where this is going!
I would personally like to see the dispersed-continuous phase models in Eulerian framework given some more attention. For example
1) Air bubbles in water or sand particles in gas etc (with two way coupling, i.e.gas and sad influencing with each other). It would be interesting if different models for different forces are included (drag, lift, turbulence dispersion?)
2) Additionally, the macroscopically separated mixtures like oil in water etc should also be considered...
It would be of course imperetive here to include surface tension in the formulation of models as this will strongly guide the interfacial interaction.
We get a lot of such enquiries from clients for filtration of such multiphase flows which we can't consider because of the limitations in the software.
Omkar
The times I have needed this (before the present capability) were:
- modeling phase change materials, such as waxes, in heat absorption scenarios... I know this is used in the transport industries and architectural field too. I used an approximation of a step-change in specific heat, which isn't bad, but isn't strictly right either. And I'd like to be able to use it in rotomolding or other situations where the melt fluid flows (that are not as specialized as Moldflow for injection molding).... we do this by experiment now.
- trying to model the latent heat cooling effect and humidity changes of a through-flow humidifier. The existing condensation model was not applicable and I couldn't account for the humidity of the air into the humidifier using inlets & outlets. This is relevant for data centers as well as more typical architectural applications.
The ability to handle changes in pressure and temperature and volume all at the same time. Example being a fluid in a piston that is changing volume where the fluid enters at one temperature, but there's a different exit temperature.
I like Omkar's #2.
We do a decent job of mixing, but being able to unmix seperable fluids like oil/water does come through support more often then the other points mentioned so far.
My vote will be for condesation in AEC modelling, multiphase materials and yes; surface tennsion too 🙂 simulation CFD will be more fun with these features 🙂
Have you looked at the condensation results in Humidity analysis?
I would be curious as to what applicaiton you find that surface tension is critical?
It would be great to be able to simulate the evaporation and then condensation formed due to a free volume of fluid (flowing or stationary), depending on geometry, heat, flow and atmospheric conditions.
Particularly to be able to evaporate, using the solar heating module already incorporated in the solver.
The aim of this simulation would be to obtain the evaporation rate depending on geometry and conditions, and also determine the location and quantity of condensation (which is already available in the solver).
DH
Hi Royce Abel!
Sorry, i haven't checked at the condensation results in Humidity analysis. Is there any tutorial of help link regarding this?
Thanks! 🙂
I don't think there is much in detail around humidity, but here are the guidelines: http://help.autodesk.com/view/SCDSE/2015/ENU/?guid=GUID-599627EC-C556-42DC-9415-BB50BFCBFFC8
We'll see about going into more details on this model type in a future hangout.
Thanks!
