CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Pivot Point Coordinate Entry
2 REPLIES 2
nathan.alday
237 Views, 2 Replies
I have a user-interface question.  It used to be that you could define where you wanted the view pivot-point to be (x-y-z sliders, I believe).  I can't seem to find the command anymore, and the automatic pivot point is driving me crazy (big external flow problem, with the object of interest way off to the side of the model volume).
Better yet - is there a way to make the model origin the pivot point, automatically?
Thanks!
- Nate
2 REPLIES 2
You can use the navigation wheel and if you click on the drop down in the bottom right hand of the navigation wheel, you can select "restore original center" and it should place the pivot point on the model origin.
Hope that helps.
Heath Houghton
Principal Business Consultant
Heath - thanks for the suggestion.  I tried it - and all it did was reset the pivot point to the centroid of the model volume (not my model origin).
- Nate
