Hi there,
I am totally new to the world of simulation but online tutorials and a bit of fooling around have given me a good idea of how to simulate air flow through a nozzle. However, I was wondering whether it would be possible to include particles into the air flow, the reason being that I am trying to simulate a jet of air carrying abrasive grit and wanted to show the motion of the particles through different nozzle shapes.
Thank You
Alain
Yes you can first obtain a converged solution of air flow in the nozzle. And then use massed particle lines to simulate the grit.
Hi, Apolo,
Could you please post the link to the simTV video?
Also, any tutorial on how to add massed particle?
Thanks!
Pei-Ying
Here is the link for SimTV with all the quick videos we post there.
yes you wuld be able to model a nozzle and a plate to see how the nozzle projects the particles on to the plate.
To do this you will need to model the nozzle the air domain between the nozzle and the plate and then the plate as well
Consider this -
Black is the air domain
Green is the nozzle at some distance above
Red is the plate
Boundary conditions would be needed at the inlet of the nozzle (on top as oriented by the quick sketch) as well as the outlets on the lateral sides of the domain.
Hi, I can't find the link to the SIMtv on your last post, also with respect to the modelling.
Apart from the plate and the nozzle, and air space has to also be designed? how would I go about doing so.
Finally I was wondering whether the particles could be fed at a flow rate rather than all at once from the grid intersections?
