Discussion Groups
Simulation CFD
New Member
0 Kudos
Options unavailable for autodesk cfd simulation 2013
154 Views, 2 Replies
10-13-2013 06:44 AM
Hi there. My name is Dashen i am currently using the Autodesk Simulation CFD 2013 software to run an external air flow simulation over a certain component. i figured out that i do not have the SST K- omega turbulence model option when i invoke the solve command. i also do not have the layer gradation option as well when i invoke the Mesh Enhancement option. May i know why i do not have such options available? Thank You.
Distinguished Contributor
34 Kudos
Re: Options unavailable for autodesk cfd simulation 2013
10-13-2013 10:20 PM in reply to: dashendhanabal94
Hi Dashen
Those features are only added in the 2014 version. If you are on subscription, you are entitled to free software upgrade.
Regards
Ilyas
New Member
0 Kudos
10-14-2013 08:16 AM in reply to: dashendhanabal94
Ok noted!! Thank You very much!!
