Hi there. My name is Dashen i am currently using the Autodesk Simulation CFD 2013 software to run an external air flow simulation over a certain component. i figured out that i do not have the SST K- omega turbulence model option when i invoke the solve command. i also do not have the layer gradation option as well when i invoke the Mesh Enhancement option. May i know why i do not have such options available? Thank You.
Solved by ilyas_drawbridge. Go to Solution.
Hi Dashen
Those features are only added in the 2014 version. If you are on subscription, you are entitled to free software upgrade.
Regards
Ilyas
