Hey,
I've been trying to run a natural convection study on a simplified enclosure (as a starting point). I've been through the tutorials. My Air is set as variable. I do not have any extra boundary settings other than Pressure and temperature on the inlet and outlet of the external volume.
Please help as i've tried everything.
Regards
Sandeep
Hi Sandeep,
Few points to make here:
Kind regards,
Jon
Hi Sandeep,
Surface Boundary Conditions (BC's) can only go on the external boundary of the model. Some of yours are inside the outer layer of air, which will not work.
Either move the BC to the outer surface or suppress the outer volume from the mesh. Same goes for the ones at the bottom.
Hi Jon
Apologies Jon, but i am confused. There are exactly 3 boundary conditions all of which are in their respective areas as demonstrated by the natural convection tutorial. Please correct me if i am wrong, I've put a pressure condition and a temperature condition at the bottom of the external air and a pressure condition at the top of the external air. There are no Surface area boundary conditions present inside the external air volume.
Please refer to the new design study i've uploaded with this post.
Sandeep
Sandeep,
Just to be sure as you answered it before however I want to be clear.
Is this model's air domain supposed to be ~82m tall and the enclosure roughly 17m tall?
At this size I can't imagine that 200W would heat the block much
That is what is in your latest model you attached. I would recommend checking as you might have a scaling issue (note the 8e4 on the Bounding Box which would correlate with 8e4mm based on your length units)
Also I noticed from some of the logs taht you were stopping the analysis after a 10 or so iterations. The thermal solution does progress a bit slower at the beginning to help with stability, and as such if you run it out thermal results do eventually show although I'm not sure if this is expected given size of the model overall
I have analyzed horizontal tubes array heated by ambient air in free convection. . I used external volume acording to enclosure sizes. Boundary conditions: tubes surface 5 celcius and Pressure on the top and bottom and a Temp (Ambient) on the top. mbient temperature 25 celcius. I attached cad file and my results. I want to see your results for comparing.
thanks in advance.
Hi ihilali,
To be clear:
We should have a P=0 on top and bottom and a T (ambient) on the bottom, as the air will heat up as it rises.
Also, only use T boundary conditions internally if they are applied to suppressed parts, as we cannot use internal surface Boundary Conditions. The alternative is to apply a volumetric heat load to the tubes themselves.
Jon
Also looking purely at your results, you do not have proper mesh on the tubes. They are not showing as round and you are not capturing well the flow between them or as it dissipates away.
