Discussion Groups
Simulation CFD
Active Member
inventorlover
No Slip Walls
382 Views, 5 Replies
02-14-2013 08:47 AM
How would I add surface roughness to walls in a CFD analysis?  As far as I can tell, free slip is default.
Thank you!
Please use plain text.
OmkarJ
Re: No Slip Walls
02-14-2013 11:55 AM in reply to: inventorlover
When you define materials for your domains, there is a option for it. Second last, if I remember correctly
OJ
Product Support
Royce_adsk
Re: No Slip Walls
02-14-2013 12:08 PM in reply to: inventorlover
By default all walls are considered no-slip (0 Velocity at the wall).  You can add extra roughness from there as indicated above.  From my perspective most industrial applications do not need this setting adjusted.
-Royce
Royce Abel
Member
IanGalang
Re: No Slip Walls
03-18-2013 11:08 AM in reply to: inventorlover
anyone can help?? pleasee
now, i;m confuse too, where to set a roughness wall, because i can't define the wall in boundary condition
thankss
OmkarJ
Re: No Slip Walls
03-19-2013 01:55 AM in reply to: IanGalang
As indicated in the post above, when you define material for your domain, there is an option to specify wall roughness. You can't define wall in boundary condition because any unspecified surface is no-slip wall with zero roughness by default
You can always find information, if you look in help documentation:
http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0138-The_Proc138/0230-Setup_Ta230/0236-Mat...
OJ
Member
IanGalang
Re: No Slip Walls
03-23-2013 10:34 AM in reply to: OmkarJ
thanks omkar, i found it
