At times we might ask for you support share file.
To create this file we need go to the File menu_Save As_Save Share file_Support type. It will have an extension of .cfz
The file is already compressed, so you do not need to zip it up.
If the file is too large to attach you could always upload it to your 360.autodesk.com account (similar to dropbox) and provide a public lnk.
can you help me with this please, i have a solver problem 🙂
hi
i tried to use cfd and just before to "resolve", i received this message:
"could you send us this file in cfz..." because solver is stopped so this is my file:
thanks for helping
I am a beginner of CFDesign and trying to do a natural convection simulation with heat pipes.
The product is simulated operating in a 60 degree C environment with air vent.
Would like to know if my whole setup is corrrectly done, especially the following setting:
1. scenario environment
2. heat pipes conductivity values in the x,y & z direction.
Thanks.
Melvin
Hi
I have a problem on solver. It stops working at last couple steps.
Would you please help me to take a look on my setups, models, ..etc.
Thanks a lot.
Chester
Dear CFD Support team,
Attached is a model for simulating natural ventilation and temperature. Two problems are encountered:
1. Every time I run the solver I receive an error of model symmetry when the radiation is activated, I could not determin wihich angle subtended by the model that produce an integer symmetric pattern.
2. The analysis can be carried out with no radiation, however temperature gradient seems to be plausible only for solid volumes.
All other air volumes (other than the external environment) do not represent variations in temperature although having the same thermal boundary conditions of solids.
I'll be looking forward to your feedback.
Best Regards
Wael Mousa
