CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Natural Convection - Boundary conditions
3 REPLIES 3
66462D
1034 Views, 3 Replies
Hello!
I am having problems with setting up boundary conditions properly. The subject is natural convection.
I would like to have an open air volume with 2 solid walls (side and bottom). I set up the project and it works fine (image 1)
I also need to specify the temperature of 1 side wall to be 16 deg C. Ambient temperature must be 20 deg C. I have tried with many set up options but results are weird. The air flow is very different from results that I had with only ambient temperature set up to 20 deg C (image 2)
I even have tried with an extra wall with temperature/film coefficient boundary condition. (image 3)
Flag "use_property_ref_temp value" is set to 1 according to this soulution strategy guide:
http://knowledge.autodesk.com/support/simulation-cfd/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU...
I would be grateful if someone could give me tips/solution how to set up scene/boundary conditions properly.
Thank you.
Pablo, Student.
3 REPLIES 3
Jon.Wilde
in reply to: 66462D
Hi Pablo,
Your model looks over cosntrained to me, we should not need anything on the side walls (other than your fixed 20C - might a film coefficient be more realistic though?).
Please check out the guide here for how to set these models up - use the chimney approach.
Kind regards,
Jon
66462D
in reply to: Jon.Wilde
Hi wildej, thank you for your answer.
I just wanted to simplify model in order to save time needed for solving . The situation I want to simulate is a radiator situated near one wall (which have temperature 16 deg C) when the air temperature is 20 deg C.
I followed THIS guides to set up film coefficient coundary condition on the top surface of the air. I also set those conditions to 3 other sides of the air to simulate situation when air comes from the side. Image 1 in the first post shows that it worked.
Do I have to model the room or there is other approach I could do to simulate this?
Pablo
Jon.Wilde
in reply to: 66462D
Hi Pablo,
It is probably better to model the room and use a 'bucket' approach with just the conditions on the top surface of the air. P=0 and a Film Coefficient.
If you set all the walls open you will run into issues as we ideally want air only entering or exiting the domain over a P=0. If it recirculates we can end up with poor results.
Kind regards,
Jon
