Hello everyone!!
I created a model of a buiding but simulation cfd can't recognise the the volume between the model bounds and the building.
I get a message that the 2-d model is not planar but as i ve seen in other examples simulation cfd can recognise surfaces that are not planar.
I haven''t assigned materials or boundary conditions to any surface yet in case i should make some changes to the geometry first. I hope someone can check the modle that I attached.Thanks in advance.
Solved by Jon.Wilde. Go to Solution.
It is because CFD works with volumes/solids in 3D. There are only surfaces here and no solid parts.
Make them solid and this should be fine.
Jon
Dear John,
Thanks again for your reply to this and the other posts as well. I used loft (solid as you said ) and then exported to a sat file and it actually worked. here is the final model that i would like to know your opininion about.
It is very interesting that i get a substantial force transverse to the wind directrion but is it correct?
There are a few things to try to be sure.
Refine the mesh and see if it effects the result, we want to be mesh independent. I tend to refine to 0.7 and see if the results change by more than 5%.
Consider enlarging the domain width - right now you are probably artificially accellerating the flow around the sides of the building
Why are you running compressible? I would think this could significantly throw the results, I would stick to incompressible, your flow rates are only 40m/s
Hope that helps!
Jon
