In the help file, it is mentioned that some motion parameters can be changed mid-run.
But when I changed the resistance force, the job can not continue to be calculated.
Why? Does anyone encountered the same problem? Attached is the help file and error.
Thanks very much.
Hi Amy,
Could you attach your model and the steps you sent through to generate the error message in detail? There very well could be a bug here that I could submit to development.
Royce
Hi Royce,
I tested the example axial-check-valve, the steps as follow:
Solve 100 steps using the parameters according to the help file.
Then modify the compression force from 44.5 to 48.4, and continue solve from t100, the error message appeared.
I tested several parameters, the error is same.
Thanks.
Amy
