CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Motion Parameter Change Mid-run
2 REPLIES 2
amy.jin
280 Views, 2 Replies
In the help file, it is mentioned that some motion parameters can be changed mid-run.
But when I changed the resistance force, the job can not continue to be calculated.
Why? Does anyone encountered the same problem? Attached is the help file and error.
Thanks very much.
2 REPLIES 2
Royce_adsk
in reply to: amy.jin
Hi Amy,
Could you attach your model and the steps you sent through to generate the error message in detail?  There very well could be a bug here that I could submit to development.
Royce
Royce.Abel
Technical Support Manager
amy.jin
Hi Royce,
I tested the example axial-check-valve, the steps as follow:
Solve 100 steps using the parameters according to the help file.
Then modify the compression force from 44.5 to 48.4, and continue solve from t100, the error message appeared.
I tested several parameters, the error is same.
Thanks.
Amy
