Hi Folks,
Does anyone know of a way to model a heat pipe. I not really after explicitly modeling the phase change and I know that I can't do it anyway, but just the energy transfer from A to B given the characteristics of a particular heat pipe.
Any help would be much appreciated and I am just after a general approach
Solved by apolo_vanderberg. Go to Solution.
Anthony,
Typically for heat pipes the generic approach is to model the heat pipe as 2 volumes
The (typically) Copper casing/pipe
The core (where all the phase change happens) as 1 lump inner volume (can be easily one if you shell the Pipe and let CFD autofill / void fill this.
The pipe would get assigned as Copper and the core would get set as a custom material typically with a low density (perhaps around that of Air) and a high conductivity (5,000 - 20,000 W/m-k)
Apolo
