Discussion Groups
Simulation CFD
Member
jontygeethu
Accepted Solution
Meshing and heat generation question
104 Views, 2 Replies
06-26-2013 09:50 AM
If I need only flow without any heat transfer, does the automatic meshing mesh only the surfaces or the solid parts or does it still mesh the entire 3D volume?
Also, instead of heat geneartion can you have a negative vale (i.e. heat absorption) this would be a simplified AC cooling coil.
Geethu
Please use plain text.
Product Support
wildej
Re: Meshing and heat generation question
06-27-2013 01:14 AM in reply to: jontygeethu
Hello Geethu,
You are correct, yes. Although this is not an automatic process, you can suppress any solid parts from the mesh and just run with the fluid only.
You are also correct with the technique for modelling heat loss from a model. We typically apply this to a solid part (try to avoid internal surface boundary conditions).
Kind regards,
Jon
Jon Wilde
Member
jontygeethu
06-27-2013 10:08 AM in reply to: wildej
Thank you Jon.
