CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Meshing advice for rotating devices
1 REPLY 1
marco.mueller
514 Views, 1 Reply
If your simulation contains a rotationg device (rotating region) the meshing process usually takes more time since there have to be several additional calculations at the beginning of the analysis. If there has to be furthermore some investigation in different meshing options / mesh sizes the following process may help you to reduce the time needed for this:
- set up the simulation (with the rotating region) and the mesh sizes
- clone the scenario and assign for the clone the fluid material to the rotating region(s)
- Generate the mesh (/solve for 0 iterations) and evaluate the mesh
- if the mesh is appropriate: delete the clone and solve the original scenario
(- if not: repeat the procedure and make sure to change the mesh sizes for the original scenario)
A different approach would be to tune the mesh at the beginning for one scenario and at the end (after the mesh has been successfully created) specify the rotating region.
Marco Müller
Product Support Specialist
Digital Simulation
1 REPLY 1
vexan99530
in reply to: marco.mueller
  I've been asked to look into the possibility of setting up a small cluster using Windows HPC Server 2008R2, and running Autodesk Simulation CFD on it.
Sarkari Result     Pnr Status      192.168.1.1
