I am getting the error message "Mesher Can not read data file:/mesher/.mci Error:The system cannot find the path specified." when I try to solve a simulation.
I checked the simulation's folders, and there is a folder named "mesher" with a file in it named "Scenario 1.mci". I don't understand why it is not letting me solve.
I just installed version 13.1, and am using it on a 32 bit Windows XP machine.
Please move your design study to a local drive.
If you are on a P: drive or a network share //PCName/folder_location/ our mesher will not always have the same level permission as your user credentials. Move this to your local C: drive and you should be able to proceed forward.
This happens regardless of whether I am on a network drive or local drive.
I moved it to my local drive then went into all the folders/files and made sure I had full permissions and everything was unlocked, but it still gives me the same error.
