I am trying to export my mesh to a .unv file. I am click export mesh, and I see a "mesh export" file under my design scenario, but I cannot find the .unv file. Where is this file sent?
Solved by Royce_adsk. Go to Solution.
This post was worked in a case:
The road block turned out to be because had had surface parts and was trying to export with mesh enhancement turned on which is not supported.
I have the same problem, can't find the unv file generated by the universal mesh option. My model only has solids.
Thank you in advance,
Rogelio
