CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Mesh Element Aspect Ratio
3 REPLIES 3
3699 Views, 3 Replies
In the case of a model that meshed successfully but gave known erroneous results, is there a way to get information on mesh element aspect ratios in the model?  Maybe maximum element aspect ratio, for instance?  This could be a way to determine that highly distorted mesh elements are causing the bad results, leading the user to investigate his CAD model geometry more closely in the affected area.
3 REPLIES 3
Jon.Wilde
Sure, you can do that.
Go to Solve -> Results Quantities and turn on Stream Function.
Run the analysis from your last iteration for 0 iterations, just to add this in.
Now you can plot Nodal Aspect Ratio as a result, I suggest ISO surfaces.
Jon
in reply to: Jon.Wilde
I am using audodesk simulatino multiphysics instead of autodesk simulation mechanical.
I have imported an IGS file to carry out static analysis.
Can you please tell me after i mesh my assembly, how can i view the aspect ratio??
Jon.Wilde
Can I suggest you post this in the Mechanical Forum?
