Here is a guess. For typical massless traces, the Langrangian equation is solveed only for particle position. It can be done using the global velocity field that is already calculated during solution. In case of massed particle traces, the velocities of particle at any point may/will be different than the local velocities of fluid. Hence the equation for local particle velocity is solved, based on Newton's second law, i.e. Rate of change of momentum=Buoyant and drag forces etc.
Now, I pressume that the particle velocity equations may have been solved explicitly, with timestep size we specify in that box. Essentially, since it's explicit methodology, the value of timestep will have an influence on accurcy of velocity. Typically, the timesteps should be chosen such that particle will cross one cell distance during the timestep, a concept perhaps equivalent to particle cell courant number.
Appropriate timestep can be: Typical cell size/mean velocity at the cell.
Though, this all is guesswork. More experienced folks may have more thoughts to offer.
OJ
