How about mesh adaptation? Or, if you know now the sensitive areas of high velocity gradients, you can ceate regions at these places for a good resolution of velocity field.
Thanks for the suggestion. Adaption is a possibility. But, I would like to first resolve this issue without adpation.
How to create region?
I remembered that there is a way to find out bad quality elements, but, cannot remembered how. Also, refining elements sometimes make things worse.
Pei-Ying
Have a look at the picture, it shows where you can find Regions. You can use cylindrical, spherical or box shaped regions.
The localised high velocity is a typical sign of divergence. I would improve the mesh and give it a try, and if it still gives problems, try reducing the underrelaxation factors in Solve>>Solution Control window. Also if you want to see the quality of mesh, enabe "Stream function" in Solve>>Resullt Quantities and once you finish meshing observe the results of "Nodal aspect ratio". You may want to see the iso-surface of it so you can understand where the bad elements are located.
Also, for a steady simulation, enabling Intelligent Soluction Control also helps in preventing divergence.
I am seeing something very strange. During steady state calculations, I saw very high maximum velcity values on the legend (something like 330 m/sec). However, the case converged at iteration #238, and all of a sudden, the maximum velocity value droped to a very reasonable value, around 17 m/sec.
What happened?
Pei-Ying
Maybe you had your legend fixed at a certain value and then when the results came in it reset the legend to auto range?
Hi, Royce,
This is a puzzle to me. I believe that the legend was set to auto. If the values were fixed, it will most likely be fixed to a reasonable value (ie, not very high).
On one case, when I stopped the steady state calculations prior to convergnce, I did see 3 "spots" that had very high local velocity. However, when I re-run the case (starting from step = 0) and let it run to convergence, these local high velocity were gone (dropped from like 333 m/s to 20 m/s).
I will see if I continue to see this phenomon.
Pei-Ying
