Discussion Groups
Simulation CFD
Active Member
viktooor
labyrinth packing
221 Views, 4 Replies
10-16-2012 02:48 AM
labyrinth packing
At the entrance of 1000 Pa. medium air
The rotation of the shaft 10 000 rev / min.
The clearance between the shaft and the labyrinth 0.15 mm
Determine the leakage of air through the maze.
Placed at the output of 0 Pa.
In solving are too little speed honey shaft and labyrinth.
Help
Please use plain text.
Active Member
viktooor
Re: labyrinth packing
10-16-2012 02:54 AM in reply to: viktooor
Product Support
wildej
10-16-2012 04:52 AM in reply to: viktooor
Please could you be a little more specific about the problem? I understand that you have 1000pa on one side and 0 on the other, the unit is rotating and you have a small clearance.
Do you have a very good mesh through that small gap?
What do you mean by 'In solving are too little speed honey shaft and labyrinth' ?
Jon Wilde
Active Member
viktooor
10-16-2012 06:54 AM in reply to: viktooor
The situation is this.
For large shaft speed of the maze thrown oil.
Necessary to analyze and optimize the design of seals labirintnogno
Product Support
wildej
10-16-2012 07:00 AM in reply to: viktooor
OK, those help. What about the mesh on the cut-plane? You need a good 4-5 elements though each of those gaps ideally.
What is your actual question, are the results not what you are expecting to see?
Jon Wilde
