I have set up the solver to record results every 100 iterations. Works fine, all OK.
How - via the python API - can I loop through each of the recorded result-sets of the scenario ?
At the moment I have to select each result-set manually through the UI, and then run my python script to extract the data I want.
(All the examples you provide just seem to operate upon the 'active' results).
Thank you for the reply, but unfortunately much the response I had expected.
It is a very regrettable omission from the python API, as the ability to 'loop' through data is a fundamental programming paradigm.
The inclusion of an API is a very valuable feature, in many situations it can enable the user to develop highly efficient workflows, providing the user with a competitive edge and thereby a significant factor in their choice of software package. The ability to programatically select an object is bare-bones functionality, and really does need to be included.
Ian
