I recently downloaded the 2015 version of Simulation CFD and was happy to see that this also installed an add-in with SpaceClaim that launches the active model in Sim CFD 15. However, my happiness was short-lived since this link between SpaceClaim and Sim CFD doesn't really work well for me.
Launching the model from SpaceClaim gives me topology errors and some parts of the assembly are not being imported. I face the same problem when I don't use the add-in but directly import a .step (or .iges, or any of the other neutral formats) file generated by SpaceClaim.
The only way I can get my model imprted into Sim CFD from SpaceClaim is to convert every part in my SpaceClaim assembly into a .step (or .iges) file, open and save each part as a .prt file in Pro/E, assemble the parts in Pro/E, and export the .asm file (through the Pro/E add-in).
There are a lot of redundant steps that would be eliminated if this link between SpaceClaim and Sim CFD worked as it is inteded to.
I was wondering if anyone else had similar problems and if someone has figured out a better workflow to import models from SpaceClaim to Sim CFD 2015.
Nikhil
Solved by Royce_adsk. Go to Solution.
Hi Nikhil,
Are you able to launch one of our tutorial models or just a simple cube?
My initial thoughts are that there is something in your geometry preventing a simple launch into CFD.
Jon
Thanks for the replies.
Varying the value of the asmcointol flag did work.
Props to the support team!
-Nikhil
