CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
issue of the APP-SIM CFD TO MECH
9 REPLIES 9
Message 1 of 10
812D1
768 Views, 9 Replies
I have simulated the pressure of a wing in SIM CFD.
then I wanted to transmit the pressure results to MECH by the app(SIM CFD TO MECH).
Following message was showed in the output bar.
FEA Transfer ... Started
FEA Transfer ... Process Input Files
FEA Transfer ... Process Input Files: Nodes
FEA Transfer ... Process Input Files: Elements
FEA Transfer ... Process Input Files: Elements Condition
FEA Transfer ... Preliminary Data Processing
FEA Transfer ... Centroid Location
FEA Transfer ... Calculate Centroid Pressure
**** This operation could take some time please be patient ****
Several minutes later,  nothing happened.  There was no finished message.
I have tried several times.
Can you help me?
9 REPLIES 9
Message 2 of 10
apolo_vanderberg
in reply to: 812D1
We have seen this issue and have logged an enhancement for the app.
This comes down to language preferences for list seperators.
As we try to read the csv files, we are looking for and assuming a comma (,) as the delimiter. In some system settings the semicolon (;) is used in stead and as a result the process stops.
Open the csv file with a text editor and verify if you have ; or , as the delimiter between each value.
If you have a ; then you will have to replace all ; with , (Text Editors like Notepad++ have a Find and replace all to avoid manually doing this )
Depending on how large the csv files are and how many nodes that are trying to get mapped this process can take a little bit of time. On some larger models on my laptop I have seen this process take 10-15min.
Apolo
Message 3 of 10
812D1
in reply to: apolo_vanderberg
Thank for your reply.
I have read the .csv file,and there was no ";"
My colleague did the same things, but the APP could work on his computer.
Our system are same.
Now, I am confused.
Message 4 of 10
812D1
in reply to: 812D1
Hi!
Now, my computer can't use the APP.
However, my colleague could. I can't find why.
After the APP installed, there is no the APP showed in my Autodesk exchange APP Manager.
What's the problem?
Could you give me a hand?
Thanks.
Message 5 of 10
sbcho
in reply to: 812D1
Hello.
CFD icon -> click "right mouse button" -> start the administator -> start "cfd to mech" -> run.
Message 6 of 10
yangjy
in reply to: sbcho
Thank you very much.
I have solved this problem with your advise.
Message 7 of 10
flyyyc
in reply to: 812D1
I have also had the exact same error.  I have checked and the nodes file uses commas, and I have rerun the simulation, made the model smaller, even uninstalled and reinstalled the program.  Has anybody found a solution to this?
Message 8 of 10
marco.mueller
in reply to: flyyyc
Change your "system language settings format" to english like in the attached image BEFORE exporting the SimMech file.
If you do not change that: even if you replace the semicolons (or whatever is used) manually and the mapping works, you will find later on that the results cannot be re-imported to SimMech.
Dipl.-Ing. (FH) Marco Müller
Application Engineer Digital Simulation
Mensch und Maschine Deutschland GmbH
www.mum.de/cfd
Message 9 of 10
flyyyc
in reply to: marco.mueller
Thanks for the reply,
I am just wondering because I am a native English speaker and my program runs in English, so that shouldn't be a problem.
Message 10 of 10
flyyyc
in reply to: flyyyc
I am still having trouble with this, and I am wondering if it is because in CFD I created an extended volume. Does anybody have any knowledge on this?
