Discussion Groups
Simulation CFD
matthew.brown
Re: Inviscid Analysis
01-18-2012 03:03 PM in reply to: matthew.brown
Royce,
I do.  We have been avoiding using it though because it has been very problematic for us. I can run this in 2012 overnight if you think it will make a difference.
Please use plain text.
Product Support
Royce_adsk
01-18-2012 03:04 PM in reply to: matthew.brown
Just checking so that if I do some test on my end I can give you a share file to try out on yours.
-Royce
Royce Abel
Product Support
Royce_adsk
01-18-2012 03:11 PM in reply to: Royce_adsk
Can you give more detail on what you are looking for in the results?
-Royce
Royce Abel
matthew.brown
01-18-2012 03:32 PM in reply to: matthew.brown
Royce,
We are comparing pressure coefficient and velocity ratio distribution.    I have attached the published results for your reference.
Product Support
Royce_adsk
01-19-2012 05:28 AM in reply to: matthew.brown
Matt,
Here are my results from last night.  Do they look reasonable to your expectations?
-Royce
Royce Abel
matthew.brown
01-19-2012 06:10 AM in reply to: matthew.brown
Royce,
This is basically what I was seeing.  This really isn't very similar to a potential flow solution though.  There would not be low velocity regions on the airfoil surface (indicating separation), rather the flow would be attached and tangent all along the wall.  The problem is probably too basic for this software to handle.  This isn't too bad though.  It will still give us something close, I think.  Thanks for the effort!
Product Support
Royce_adsk
01-19-2012 06:22 AM in reply to: matthew.brown
Matt,
One last thing for you to checkout.  I turned on the quick forced flow solver.  When Quick Forced Convection is enabled, the flow is computed using a potential flow computation that is complete in one iteration.  When there is no heat transfer boundary conditions present, the heat transfer portion of the analysis is skipped.
-Royce
Royce Abel
matthew.brown
01-19-2012 06:25 AM in reply to: matthew.brown
Royce,
PERFECT!!!  This is exactly what I was trying to do.  Thanks!
-Matt
New Member
RitaSchnipke
01-19-2012 06:28 AM in reply to: matthew.brown
You should be able to run a potential flow solution using the "Quick Forced" option on the "Solve-Physics" widget. You don't need to set any thermal conditions. This should give you a potential flow solution to your problem.
Product Support
Royce_adsk
01-19-2012 07:24 AM in reply to: matthew.brown
Matt,
Here is my share file.  If you could share your results on how they compare to the published results, that would be excellent!
Royce
Royce Abel
