Discussion Groups
Simulation CFD
5 Kudos
Inviscid Analysis
554 Views, 24 Replies
01-18-2012 06:47 AM
Does anybody have an idea of how one might approach an inviscid (essentially potential flow) analysis using CFDesign/Simulation CFD?  Is this even possible?  Any advice would be appreciated.  Thanks.
Product Support
231 Kudos
Re: Inviscid Analysis
01-18-2012 07:02 AM in reply to: matthew.brown
Hi Matt,
This is possible!
Procedure for simulating an Euler (inviscid) flow solution with standard solvers:
1. Create a material with a viscosity of 0 (or very close to 0).
2. Assign slip to all the solid walls
This removes viscosity from the solution.
Another option is that you could use the 'Quick Forced' solver (Quick Forced has a potential flow solver).  Solving for potential flow naturally ignores wall constraints and fluid visocity so the above settings do not need to be followed.
Note: a viscosity that is exactly 0 can cause solution instability. If you see this, use a value that is very close to 0 (such as 0.000001 Poise).
(LINK)
Royce Abel
5 Kudos
01-18-2012 07:09 AM in reply to: Royce_adsk
Royce,
Thanks! I will give this a shot.   I am curious though, why the slip BC at the walls?
Product Support
231 Kudos
01-18-2012 07:35 AM in reply to: matthew.brown
When you make the assumption of Inviscid flow you also expect that there be slip at the walls, therefore you need to add the slips.  Otherwise you would still get a 0 velocity along the walls.
-Royce
Royce Abel
5 Kudos
01-18-2012 02:08 PM in reply to: matthew.brown
This (sort of) worked.  I was not able to get it to run smoothly using viscosities less than 1e-4 poise, and even then I needed the 'Check Velocity Distribution' flag file command to get it to finish.  Ultimately, however, this did not get me to the results I was shooting for.  There is still a large amount of laminar separation, which is what I was trying to avoid, so that I could check the results of a potential flow calculation.  Any thoughts?
Product Support
231 Kudos
01-18-2012 02:15 PM in reply to: matthew.brown
Would is be possible for you to share your support share file?  Would you consider it NDA or have something that you could mock up quickly?  Otherwise we will have to take it offline to a real case.
-Royce
Royce Abel
5 Kudos
01-18-2012 02:37 PM in reply to: matthew.brown
Royce,
 It is not proprietary.  The file is supposed to represent an annular NACA 66(2)-015 airfoil.  There are experimental and potential analysis results published in Lewis, 'Vortex Element Methods for Fluid Dynamic Analysis of Engineering Systems' Cambridge University Press, (C) 1991.  He offers a Pascal code in the back which we are trying to use, but his code results do not match what he published.  We are trying to decide if his results are incorrect or if it is his code that is faulty.  The analysis is laminar and axisymmetric in X.  Also, I am using CFDesign 2010 not Simulation CFD if that makes a difference.
That all being said, the website will not let me attach a *.cfz file.  I get the following error:
Product Support
231 Kudos
01-18-2012 02:39 PM in reply to: matthew.brown
That is odd.
Change the extension to .cfz.txt
-Royce
Royce Abel
5 Kudos
01-18-2012 02:41 PM in reply to: matthew.brown
Here ya go!
Product Support
231 Kudos
01-18-2012 02:59 PM in reply to: matthew.brown
Matt,
Do you have access to CFD 2012?
-Royce
Royce Abel
