CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Inventor - Launch Active Model very slow
9 REPLIES 9
Message 1 of 10
DWhiteley
1089 Views, 9 Replies
I've got a 250 part assembly that I am trying to Launch to CFDesign 2012 from inventor 2012. It takes about an hour before I have to kill the process! I seem to be getting hundreds of "Executing Edit Attributes" messages at the bottom of Inventor.
Any ideas?
9 REPLIES 9
Message 2 of 10
derrek.cooper
in reply to: DWhiteley
Hi Dave.. An hour seems longer than I would have expect. But, each of the part attribute data is being written prior to launch, so that is the messages you are seeing. We do that so that we can leverage associativity and some of the automation to track the parts location and material data etc.
How much memory do you have on your machine?
A quick test would be to solve as an ACIS (*.sat) and read it in direct. This will by-pass the attribute writing and will be faster, however, it will also not allow you to leverage associativity.
We can take a look at the model to give you a better idea. It will fall under NDA, of course. Would be a good test model to see what we can do to speep up the process.
derrek
Derrek Cooper
Director, Inventor Products
Message 3 of 10
DWhiteley
in reply to: derrek.cooper
I have 8gb RAM Derrek. I'll try using SAT to see if that helps. Thanks for your fast reply.
Message 4 of 10
DWhiteley
I tried uisng SAT but got a licence error - ****!!!!
Message 5 of 10
derrek.cooper
Dave.. if this is still an issue, ping me in the AM and I can work to give you a temp license to get you going
derrek
Derrek Cooper
Message 6 of 10
DWhiteley
Thanks for the offer Derrek, but we're going to order the relevant NFR today.
Dave
Message 7 of 10
I am also having the same problem with Inventor.  I have had to rely on the SAT files for all simulation CFD imports.  The "Launch active model" button just doesn't seem to do anything for a really long time.  I have left it overnight before, and CFD is brought up in the morning.  That is too long in my opinion.  The model is not even close to 250 parts either, and the SAT files work just fine importing directly.
I have attached the file that I am using.  It is somewhat big, but my computer is more than capable of handling it.
Thanks for the help,
John
Message 8 of 10
I guess I should include the referenced parts in this assembly.  I will have to email them to someone as I cannot attach all of them.
It is interesting to note that when I import this model via SAT format, the simulation does not run correctly.  In this particular case the wheels spin much faster than if I were to use the "Launch active model" button.  However, I am 4 hours into waiting for this button to do anything.
John
Message 9 of 10
marco.mueller
Hey John,
I've seen that if you create parts from scratch in Inventor 2014 this problem seems to be gone (pretty much), loading times are faster.
Also you can import iam/ipt to CFD 2014 directly without conversion to SAT, which is faster.
If you use SAT files instead,  the unit may be not transferred and has to be changed in CFD, that may be the reason for the deviance.
Marco
Dipl.-Ing. (FH) Marco Müller
Application Engineer Digital Simulation
Mensch und Maschine Deutschland GmbH
www.mum.de/cfd
Message 10 of 10
I'm sure there are many bugs that have been fixed with 2014.  However, the team that I am a member of uses 2013 inventor and, while I could still use CFD 2014, inventor 2014 is not an option because 2013 will not open anything made in a later version.
Is there any fixes for the 2013 package?
john
