Solved by apolo_vanderberg. Go to Solution.
Solved by Royce_adsk. Go to Solution.
Hi mh,
I'm no expert in this but I just want to share my thoughts.
The first image is the software looking for the license server. If you did not point the software to the license server, then that would explain the subsequent error messages.
Regards
Ilyas
mh -
Your issue is relattively common. From the flex license server log file we an see that you did not register all of your serials. You are missing the increment and package for the interface (Design Study Environment). Without this you cannot open the software.
Check out this tool to view in detail what is in your license file.
http://licenseparser.com/index.html
-Royce
Hi Royce
Please see attached file. Problem still stands.
BR
MH
