CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Installation Problem - Help me
25 REPLIES 25
Message 1 of 26
hareesh.kalyan
1776 Views, 25 Replies
i have istalled with stand alone licence
I installed Network licence manager
25 REPLIES 25
Message 2 of 26
I am also facing this exact problem. I installed Autodesk Simulation CFD 2013 as stand alone but when I start the application, the software seems to look for the network licence. FYI, the machine initially had LMTools installed for other Autodesk Software, I don't know if there is any relation to this. What might be the issue?
Message 3 of 26
Have the two of you looked at the following Knowledge Base Article?
ADLM Startup Failure
Message 4 of 26
thank you for the solution.Now I am able to activate the liscense.
but when launching cfd simulation it has stopped working.
please help me i actually need urgently
Message 5 of 26
The interface crashes? Or does it give an error?
You said when launching , are you launching a model frmo CAD to CFD? Or just opening the UI on its own?
Message 6 of 26
the interface crashes.either i launch from solid works or launching by double clicking the icon autodesk simulation cfd 2013.
Message 7 of 26
Can you give me some details on the graphics hardware you're using?
When you installed this you did (for Vista / Win7) right-click and "Run as Admin" even if you are an Administrator?
Apolo
Message 8 of 26
ya i did by right clicking. hardware: 4gb RAM, 1GB ATI graphic card,
Message 9 of 26
Royce_adsk
in reply to: hareesh.kalyan
My guess to the solution would be covered in this up and ready article:
http://upandready.typepad.com/up_and_ready/2012/06/autodesk-simulation-cfd-2013-crashes-at-startup.h...
Also make sure that 'TabletInputService' or 'Tablet PC Input Service' is disabled in your services list in Windows.
-Royce
Royce.Abel
Technical Support Manager
Tags (1)
Message 10 of 26
hareesh.kalyan
in reply to: Royce_adsk
i couldnt resolve the issue.please help me. i have attached the image of the problem
Message 11 of 26
hareesh.kalyan
actually i unistalled the autodesk and then i again installed it.now its working fine
Message 12 of 26
thank you very much dude
Message 13 of 26
now the problem is when i am launching autodesk cfd simulation from solid works it is not even responding
Message 14 of 26
Royce_adsk
Could you post your log file?
It is located here
C:\Users\username\AppData\Local\Autodesk\Simulation CFD 2013\Simulation CFD.log
Royce
Royce.Abel
Message 15 of 26
Royce_adsk
When testing the launching from Solidworks follow these two steps first
1) Need to launch from a local drive.  Launching from the network can cause issues.
2) Test with something simple like a block first.
-Royce
Royce.Abel
Message 16 of 26
hareesh.kalyan
i sending the file.plese look into it thank you,
Message 17 of 26
hareesh.kalyan
i am sending the log file
Message 18 of 26
even though i try with the blocks, i couldnt launch it.
actually when launch the autodesk cfd simulation in active mode in solid works it is not responding.
Message 19 of 26
Hi
Have tried to install and run CFD with other Adesk software. Tried everything you have mentioned here and start even a topic ( http://forums.autodesk.com/t5/Installation-Licensing/Cannot-initialze-License-manager-ADLM-startup-f... ) and did everything is mentioned there. Nothing works for me so PLEASE HELP:
Today I installed a new HD with fresh windows7 installation and first Software is CFD. I attach some pictures and logs please se if you can help me.
Message 20 of 26
Hi again,
As you cad upload only 3 files here is the rest.
