CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Indirect gas fired heat exchanger
5 REPLIES 5
tugberk_ozar
492 Views, 5 Replies
Good days,
I am trying to simulate a natural gas combusted air heater.
unfortunately, there is not a combustion model for sim cfd.
I am trying to model it as a 0.99 resistance metarial with a heat generation and created a flue gas metarial with its thermodynamic properties then with a volume flow rate moved it through to the resistance, but the results are not satisfying.
Is there anyone who tested this king of a simulation?
Thanks.
5 REPLIES 5
Jon.Wilde
in reply to: tugberk_ozar
It sounds like your approach is OK. Can you describe (or show) your setup vs real life and also detail what is not satisfying about the results?
Thanks!
Jon
tugberk_ozar
in reply to: Jon.Wilde
Thank you for your reply mr Wilde.
May I send you the support file?
Jon.Wilde
Sure, can you post it here?
Please also provide some details about what you are seeing from CFD vs what you are expecting to see.
Many thanks,
Jon
tugberk_ozar
I am recently trying to simulate an industrial heater which is Accorroni Mec C 35 and i am also sending its specs. That is a school project of a friend of mine and i know that the product have some over heating problems so firstly i am trying to simulate the ral product then i wish to make some upgrades on the design.
And my problem is on analysis i am reading unrealistic temperature values like 1*E6 C. after some mesh independent analyses results did not change.
Jon.Wilde
This is a pretty good setup to start with, nearly there I think.
A few things though:
  1. You need to split the fan up so that the inlet surfaces and the outlet are not sharing an edge - so increase it's diameter so it is wider than the inlets and then extend it's length so it is touching the surfaces
  2. Extend all inlet and outlets to 5x diameter in length
  3. Refine your mesh - the fan needs a uniform mesh and you will need far more in the gaps within the heat exchanger. Aim for a minimum of 4-5 elements through gaps globally as a starting point
I hope that helps,
Jon
