Is it possible to apply a steam boundary condition (e.g., select humidity and enter a value of say, 50%) to an edge of a 2D axisymmetric model? Or do you have to apply this to a surface? Thanks,
paul
Solved by Jon.Wilde. Go to Solution.
Sure, that is correct.
Volumes in 3D = Surfaces in 2D
Surfaces in 3D = Edges in 2D
Hope that helps
Jon
So I applied a Quality BC to an edge (in my case, 0.8 to represent 80% steam quality) as well as a film coefficient (see attached image) to represent a hot steam gas being applied on a steel surface. For reference, the geometry is of the structure only, so no fluid is modeled in this case. When I attempt to solve the scenario, I get a message stating that I need to select a fluid material with Saturated in the name. My sense is that this material allocation is for the fluid that is in contact with the structure, which for a 2D case, would be an adjacent surface in contact with that edge.
Do I need to model the contacting fluid for steam quality BC to work?
Hi Paul,
Yes, you would only apply a steam BC to a fluid.
Shall we take a step back and look at your model so we can get an understanding of what you are trying to achieve?
Could you share some images and goals?
Jon
The problem that I'm trying to solve is actually an inverse heat transfer problem. I have a 1" thick wall stainless steel canister that is 30" in outer diameter. Inside it is water at room temperature that is filled to some unkown height. Above the water is a hot gas that ranges anywhere from 300-400degF (I'm assuming a low h value).
I have thermal data on the outside of the canister wall that tells me temperature vs time along the height of the canister.
My goal is to figure out what is the height of the water to within +/- 2 inches.
My first approach to solving this is to model a 2D axisymmetric profile of the canister and then apply a range of hot gas temps and water temps on the inside wall of the canister. Then run the simulation over a period of xx seconds to see if it matches my data. I set up the 2D model to just represent the canister (and not the fluid) because I thought I could represent the fluid/steel interface as a BC and therefore minimize the size of the model. Maybe I need to include the fluid?
Ideas? Comments? Am I approaching this completely the wrong way?
Hi Paul,
Thank you for sharing, here are a few thoughts:
This should work OK I think, please let me know if you have any further questions.
Thanks and have a nice weekend 🙂
Jon
No problem, please do ask if you need more help. Or mark the post as a solution if it provided you with one 🙂
