Yes 🙂
It should automatically identify how many you have when you installed.
You can also specify how many through a meshing flag
Jon
Jon,
Have you noticed any quantifiable improvemnet in meshing time for large meshes when you enable multicore?
I generally enable multicore meshing but I have not noticed any significant difference.
Regards
Omkar
Jon, thanks for this tip. I noticed in the above link that "Multi-threaded meshing does not support Volume Growth rate and Boundary Layer blending options from the Advanced Meshing Controls dialog." I use the first one a lot so perhaps that is what leads to single-threaded meshing for me...
What does "Boundary Layer blending" refer to? I don't recognize that term or see it in the linked help page. Is it referring to the flag here? http://knowledge.autodesk.com/support/simulation-cfd/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Thanks.
Boundary layer blend is a flag we can use. I would avoid it unless you are having meshing issues, should not be any need.
