CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
How to specify thermal contact resistances
2 REPLIES 2
dousti
911 Views, 2 Replies
I have two objects made of different materials touching each other. I would like to set a certain thermal contact resistance (with the unit of m^2.K.W(^-1)) for the shared area between two objects. How can I do it in Simulation CFD?
Thanks.
2 REPLIES 2
dousti
in reply to: dousti
Well, I found the answer and will leave it here in case someone is interested to know:
Link to the Solution
Royce_adsk
in reply to: dousti
That is correct!
You can also use surface solid materials and define a thickness using either conductivity or resistivity as the material definition. I typically prefer that approach.
Best regards,
Royce.Abel
Technical Support Manager
